Time Clocks
Posted by vitester on November 15, 2012 at 4:02 amI would like to get a bio metric time clock, all the ones I have found
have a monthly fee. I try to avoid monthly fees where ever possible.
Any info on clocks with a straight up purchase would be great, if there
even any!
chogan replied 12 years, 1 month ago 6 Members · 6 Replies -
Unknown Member
Deleted UserNovember 23, 2012 at 4:24 pmI am not a fan of monthly fees, but i recently went with time clocks
using the uAttend system. They are internet based, so i can view all the
data over the internet, from anywhere in the world. For the $20 per
month, it is one of the best things i ever did. It probably just depends
on how many employees you have, and how much time you spend on it now.
Joe,
Are you using the time clock for tracking the time your employees are at
your business or are you using it to track their time during the day?
Thanks!
Rick
uattend is the system I was looking at, I like that at least there is no
contracts and its month to month. I will try it and can always cancel.
You might want to take a look at Motive Power 3.5, shop management software. Motive Power is designed for independent mechanical repair shops and has built-in time clock for each tech. You can just click on and off a job to record your time. You can purchase the software with no monthly fees and us it for as long as you like. Motive Power runs on Microsoft SQL server 2008 which is supported by MS until 2019. More about Motive Power at cohenconsulting1.com.
We use Omnique Shop Management Software and it has a built in time clock that records both daily clock in and out as well as in and out on each job.
