Home » Forums » Customer Service » Survey – Testing, Inspection, Diagnosis Billing Methods
Home › Forums › Customer Service › Survey – Testing, Inspection, Diagnosis Billing Methods
  • Survey – Testing, Inspection, Diagnosis Billing Methods
    Posted by Site Administrator on March 11, 2011 at 6:47 pm
    In most cases for testing/diagnosis/inspection where more than a quick inspection is required, do you:
    _____ Charge for both repair and testing, retain the original testing charge, and show each charge on separate labor lines
    _____ Charge for both repair and testing, retain the original testing charge, and include them both in a single labor line
    _____ Charge for both repair and testing, reduce the charge for testing, and show each charge on separate labor lines
    _____ Charge for both repair and testing, reduce the charge for testing, and include them both in a single labor line
    _____ Charge for repair, and zero out the charge for testing
    Feel free to make additional comments, but please avoid mentioning specific prices and labor rates.
    rhopp replied 15 years, 6 months ago 12 Members · 12 Replies
  • 12 Replies
  • tony-gobble
    March 12, 2011 at 3:29 am
    __X___ Charge for both repair and testing, retain the original testing charge, and show each charge on separate labor lines
  • d-stroebel
    March 12, 2011 at 11:53 am
  • David
    March 14, 2011 at 6:11 pm
    _x____ Charge for both repair and testing, retain the original testing charge, and show each charge on separate labor lines
    Diagnosis charges remain on 90% of RO’s, sometimes reduced or rolled in depending upon type of work needed.
  • randi
    March 14, 2011 at 7:42 pm
    ___x__ Charge for both repair and testing, retain the original testing charge, and show each charge on separate labor lines
  • Dennis
    March 14, 2011 at 8:04 pm
    Same answer for our shop
  • phoskins
    March 14, 2011 at 9:05 pm
  • gcauto
    March 15, 2011 at 1:38 pm
    ___X__ Charge for both repair and testing, retain the original testing charge, and show each charge on separate labor lines
  • Patrick McElroy
    March 15, 2011 at 2:11 pm
  • Unknown Member
    Deleted User
    March 15, 2011 at 3:03 pm
    OK. I see where this is going; I have been known to roll testing labor into the repair. Mind you, the total is usually about the same (I don’t cut the price to make the sale, I’m more likely to pad the repair!). But I understand where that “cheapens” the value of the testing that I am now “giving away”, at least on paper. I think I got an inkling of this concept at a George Witt Class – now it is clearer and I promise to try and STOP IT. But I will still run out in the Parking Lot and pull a Code for FREE!
  • rhopp
    March 15, 2011 at 4:18 pm
    Hi Steve,
    I think I was in the same GR class…
    We have a “No Wrench” labor op used for quick free looks. Beyond that we
    use mostly a “Level 3” testing (Implying its higher than the non-existent
    level 1 & 2)
    For the most part they are separate, though can be combined if we think
    perception problem is likely.
  • Tom Piippo
    March 21, 2011 at 10:26 pm
    If I kick the fuel tank to get the pump to run… line item test fuel pump…. $0.00
    If I current ramp the pump, test pressure & volume for my 75 year old “A” customer, I add the test to the pump labor (he doesn’t understand about scopes, etc…)
    If I do the same for the 35 year old CPA… It’s itemized seperately, PLUS he gets the printout from the PICO (CPA’s love paper)
    So YES all the above (only because I know my customers)
  • rhopp
    March 23, 2011 at 2:13 pm
    GREAT Reply Tom!
