Home » Forums » Everything Else » Ignition Coil Replacement Policy (Free Sample Document from the Premium Area)
Home › Forums › Everything Else › Ignition Coil Replacement Policy (Free Sample Document from the Premium Area)
  • Ignition Coil Replacement Policy (Free Sample Document from the Premium Area)
    Posted by AMN Admin on August 16, 2021 at 4:50 pm
    Ignition Coil Replacement Policy:
    “When we are pursuing an engine miss and we recommend an ignition coil, also recommend replacing all ignition coils that appear to be the same age or older than the failed coil. If the customer chooses to replace only the failed coil, make sure the recommendation to replace the others is clearly noted on the invoice so if the car returns later for an issue related to an ignition coil that was not replaced, we have documented our recommendation to replace them all.”
    Shawn Jutras replied 5 years, 1 month ago 2 Members · 1 Reply
  • Shawn Jutras
    August 24, 2021 at 9:09 am
    Please share:
    Reply To: Ignition Coil Replacement Policy (Free Sample Document from the Premium Area)
