Home » Forums » Everything Else » Checklists after work has been completed before the vehicle goes out
Home › Forums › Everything Else › Checklists after work has been completed before the vehicle goes out
  • Checklists after work has been completed before the vehicle goes out
    Posted by linda baker on November 11, 2020 at 8:48 pm
    Does anyone have samples of checklists for work done say by a apprentice or other tradesman that a foreman can use to double check on work done on the vehicle before it goes out to the customer.
    John Shanderuk replied 5 years, 10 months ago 4 Members · 3 Replies
  • 3 Replies
    November 12, 2020 at 8:30 am
    CHECKLIST  – TECH
    Symptoms serviced corrected
    Warning lights on after service
    New information after service
    Wheel mounting surface corrosion cleaned or OK if wheels were removed
    Lug nuts hand torqued to specification if they were removed
    Clock reset as needed
    Radio reset as needed
    Parts quantity changes
    Parts not used noted
    Parts additional noted
    Parts replaced in bin
    Door sill plate clean
    Spills and debris cleaned
    Under hood label installed
    Lug nuts hand torqued again after test drive
    O/H door remote removed
    CHECKLIST  – FOREMAN / MANAGER
    Inside vehicle clean where work performed
    Outside vehicle clean where work performed
    Floor mat removed
    Add any new information
    Warning lights
    Photo of dash
    Seat position return
    Out miles
    Assigned techs correct
    Keys in front lock box
  • Randy Lucyk
    November 26, 2020 at 12:51 pm
    Our “final checks” are embebed in a quicklube module that ROWriter developed back in the day. It was ahead of its time for primarily one reason,
    “You cannot close out an invoice unless your “final Checks”  checklist is completed”.
    This single feature makes it a breeze to get compliance in filling out the inspections and final checks. There is no real learning curve or “remembering” to complete the checklist.
    I continue to be highly disappointed in every other digital inspection platform out there(including Rotouch), for not having this feature embebed in their platform.
    Unfortunately, Rowriter did not provide a easy way for me to share my inspections. In the past I did extract the data from the tables in the database for sharing elsewhere, and I have that attached.
    I believe what you are asking for is a key to providing profitable quality service by minimizing comebacks.  We will continue to enhance our “final checks” and continue to badger inspection platform developers to include the feature described.
  • John Shanderuk
    November 29, 2020 at 2:31 pm
    I have a canned job that I add to every RO.
    Can modify the N/A (Not Applicable) lines to remove the N/A if it is needed for the job. Enter techs initials or number for the “Performed By:” line. ie Performed by :  JS
    Uptown Imports – Pre Delivery Inspection
    Test driven to verify repairs completed properly
    Any other issues noted / brought to attention of advisor
    Interior / Exterior of vehicle clean of dirt and smudges
    Remove all tools from vehicle
    N/A Top up fluids / check tire pressures
    N/A Service indicator lights and or service data reset
    N/A Wheels torqued to specification
    N/A All fasteners torqued to specification
    N/A Engine covers / under panels reattached
    N/A All residual fluids cleaned
    N/A Dye added for oil leak reinspection
    N/A Dye added for coolant leak reinspection
    N/A Coolant leak repairs tested by pressurization
    N/A Intake, vacuum, breather, evap leaks re tested
    Electrical
    N/A Check function of all electrical items
    N/A Initialize windows and sunroof
    N/A Set clock
    N/A Input radio code
    Performed by:
