Home » Forums » Everything Else » U4GM Explains FH6 Italian Supercar Madness
Home › Forums › Everything Else › U4GM Explains FH6 Italian Supercar Madness
  • U4GM Explains FH6 Italian Supercar Madness
    Posted by Unknown Member on July 15, 2026 at 5:41 am
    Draft Series cards can be easy to overlook when a new Diamond Dynasty program arrives, but MLB The Show 26 has given this group enough quality to deserve a proper look. Roch Cholowsky is the obvious headliner, yet he is not the only reason to pay attention. A few of the new pitchers could fit straight into competitive rotations, while several position players offer useful depth for theme teams and collections. If you’re managing your MLB 26 Stubs carefully, this is the kind of release where patience can save you from buying a card before its price settles.
    Roch Cholowsky Looks Ready for a Long-Term Role
    Cholowsky has the profile most players want from a young shortstop. He can handle both sides of the plate, brings more power than you might expect from a middle infielder, and has the defensive tools to stay on the field. That combination matters in Diamond Dynasty. A shortstop who can contribute at the plate without becoming a liability in the field gives you more freedom when building the rest of your lineup.
    You may need a few games to get comfortable with his swing. Some players will click with it immediately, while others might find the timing a little different from the shortstops they already use. That is normal. Attributes only tell part of the story. How a card feels against inside fastballs, whether its load gets in the way of breaking pitches, and how often you square up difficult contact will decide whether Cholowsky becomes a starter for you. His versatility still makes him worth trying, especially if you are looking for a fresh option rather than another familiar name.
    The New Pitchers Could Cause Problems Online
    The pitching side of the Draft Series may turn out to be just as important. Several of the new arms bring serious velocity, including fastballs that can challenge hitters before they have time to settle in. That is especially useful in Ranked Seasons, where a pitcher with a hard fastball can force rushed swings and create better opportunities for sliders, changeups, and other secondary pitches.
    Still, speed alone will not make every pitcher effective. You will want to check release points, pitch movement, stamina, and the quality of the full arsenal. A card can throw 100 mph and still become predictable after two innings. The better options will be the ones that combine velocity with a reliable off-speed pitch and enough control to avoid falling behind in counts. Try them against different opponents before deciding whether they deserve a rotation spot. A pitcher who feels average in offline play might suddenly become useful against someone who struggles to catch up to heat.
    Use the Series to Add Depth Without Forcing a Purchase
    Not every Draft Series card needs to become a permanent part of your starting lineup. Some are better suited to Conquest, Mini Seasons, event rosters, or collection progress. That does not make them worthless. A capable backup infielder, a power bat for a theme team, or a left-handed starter can solve a problem you did not realise you had until a new program or event changes the roster requirements.
    It is also worth playing through the free content before spending heavily on the Marketplace. Earned packs and program rewards can cover more of the set than expected, and duplicate cards may sell for a healthy return while demand is high. Prices often jump when a popular prospect arrives, then cool off once more players finish the program. Check what you already own, identify the positions that genuinely need help, and avoid buying a card simply because it is new. That approach leaves more room for the next content drop.
    Final Thoughts
    The Draft Series adds useful variety to MLB The Show 26 rather than relying on one headline card. Roch Cholowsky has the balanced skill set to become a popular shortstop, but his true value will depend on how his swing fits your approach at the plate. The new pitchers deserve attention too, particularly for players who like to attack with velocity and change the pace with breaking stuff. Test everything in a low-pressure mode first, keep an eye on Marketplace movement, and hold cards that may matter for future collections. If your lineup still has a clear weakness after the free rewards are gone, you can buy MLB The Show Stubs for a targeted upgrade instead of spending without a plan.
    Unknown Member replied 2 months, 3 weeks ago 1 Member · 0 Replies
