Home » Forums » Customer Service » U4GM ARC Raiders High Score Farming Guide
Home › Forums › Customer Service › U4GM ARC Raiders High Score Farming Guide
  • U4GM ARC Raiders High Score Farming Guide
    Posted by Unknown Member on July 15, 2026 at 5:53 am
    The Search Lockers Trial looks easy until you try to push past the basic score. Opening a few lockers is simple enough, but reaching 10K points before the match turns messy takes a bit more thought. You need a route that keeps you moving, enough keys to make the trip worthwhile, and a clear idea of when to leave. The Dam Battlegrounds can punish players who wander without a plan, especially once other squads start rotating through the same areas. A good run can also bring home useful ARC Raiders BluePrints, crafting materials, and gear that makes the next deployment easier. The trick is to treat the trial as a short, controlled raid rather than a race across the whole map.
    Build a Route Around Locker Density
    Your first decision should be where to start, not which locker to open. Look for sections of Dam Battlegrounds where several lockers sit within a short walk of one another. That cuts down on sprinting through open ground and gives you more chances to score before the danger level rises. A compact loop works better than a straight line. You can clear one cluster, move through cover, and circle back towards an extraction option without crossing half the map.
    Pay attention to the spaces between lockers as well. A route might look impressive on paper, but it is a poor choice if every move leaves you exposed to ARC units or enemy players. Buildings, broken walls, service corridors, and terrain dips give you room to pause and listen. You do not need to fight every threat. In many cases, slipping past trouble is faster and safer than stopping to take a fight that has nothing to do with the trial.
    Use Keys Where They Matter
    Locker keys can disappear quickly when you open everything on sight. That is usually where a promising run starts to fall apart. Save your keys for locations that fit your route and offer a reasonable chance of useful loot. If a locker is sitting in an exposed corner with enemies nearby, leaving it untouched is not a failure. You can always return later if the area settles down, but you cannot recover the time or health lost in a bad engagement.
    It helps to think one or two stops ahead. Before opening a locker, check your key supply, backpack space, and the safest direction for your next move. Constant backtracking wastes more time than most players realise. If you have already found enough value for the trip, do not burn another key just because a container happens to be nearby. The best runs are not the ones with the most doors opened. They are the ones where every opening supports the route and the score.
    Keep Looting Tied to the Trial
    The Search Lockers Trial is a good chance to earn more than points, but it is easy to get distracted by every shiny item. Take valuable materials and rare equipment when they appear, then keep moving. Common loot can wait if your backpack is starting to fill. Spending a minute sorting through low-value items may feel harmless, yet that minute can put you behind another squad or leave you scrambling when the extraction window becomes risky.
    Try to make quick decisions. Keep the items that are expensive to replace, useful for crafting, or difficult to find during normal raids. Drop bulky, low-value gear when a better item comes along. You should also keep a little space free for unexpected finds. A full backpack before the best locker cluster is often more frustrating than helpful. The trial rewards a steady pace, so loot with purpose and avoid turning each stop into a long inventory session.
    Leave Before the Run Turns Bad
    Reaching the target score changes the value of every decision that follows. Once you have enough points and a worthwhile haul, extraction should become the priority. Staying for one more locker can pay off, but it can also erase the entire run if enemy activity increases or your route gets cut off. Check your health, ammunition, key count, and backpack space before making that choice. If several of those are running low, there is little reason to keep gambling.
    Choose an extraction path with cover wherever possible, and listen before crossing open areas. A quiet exit is worth far more than a dramatic last fight. If the nearest extract looks crowded, take a slower route rather than charging straight into danger. Successful trips build your resources far more reliably than occasional high-risk runs. The coins, materials, and gear you bring home can then be put towards repairs, supplies, and stronger equipment for future trials.
    Final Thoughts
    A strong Search Lockers Trial run comes down to simple habits: start near a dense locker area, follow a compact route, spend keys with purpose, and leave while the odds are still in your favour. You do not need to search every container or win every encounter to reach a solid score. Move with a plan, keep your inventory under control, and treat extraction as part of the objective rather than an afterthought. The rewards can support future upgrades, and when you need extra equipment for the next deployment, it is worth knowing where to buy ARC Items without wasting the progress earned from a good raid.
    Unknown Member replied 2 months, 3 weeks ago 1 Member · 0 Replies
