Home » Forums » Shop Design & Efficiency » turning ordinary techs into great techs.
Home › Forums › Shop Design & Efficiency › turning ordinary techs into great techs.
  • turning ordinary techs into great techs.
    Posted by petro on December 8, 2011 at 10:17 am
    I’m thinking of creating a check list manual for the techs
    to follow. Before they approach the foreman or workshop
    controller, They must go to the folder and find the
    diagnosis or repair check list which everyone follows
    equally. Its located in alphabetical order , So when the
    tech approaches the foreman and asks” its running rough what
    do i do now “and the response from the foreman is” did you
    check this or did you think about it”, they cant do that.
    They go through the checks and if they cant diagnose and
    they approach the foreman, He can hold them responsible by
    asking have you documented the results from the check list
    and if they respond no. He docent help them until they do
    that first , That way it frees the work shop controller and
    foreman to get on with things and not get swamped. Also
    Every one can be a champion, That way we don’t rely on one
    or two people doing the thinking. And slowing the workshop
    down, or telling customers to rebook because the foreman is
    on holidays.
    Any suggestions. I need to create in house training to help
    the techs learn complex diagnosis etc and not loose billable
    hours. Teach them to approach things like the foreman does,
    Simplify things like old school way.Motor,carb
    y,distributor,starter and ignition key. When you don’t get
    spark you check leads , distributor and coil. These days
    with electronic injection you check leads and if ok, check
    crank angle etc. I want everyone doing the same thing.
    (system)
    Patrick McElroy replied 14 years, 9 months ago 2 Members · 1 Reply
  • Patrick McElroy
    December 21, 2011 at 5:09 pm
    Hi Petro,
    One methode I utilize is to use a cooking timer with a bell for some of my “slower” techs. When he starts a preliminary diagnosis, I’ll set the timer for say, a half an hour. When the time is up I’ll check up on his progress to make sure he is staying “on track”.
