Home » Forums » Parts and Tire related topics » Tire rotation intervals – Your policy?
Home › Forums › Parts and Tire related topics › Tire rotation intervals – Your policy?
  • Tire rotation intervals – Your policy?
    Posted by Site Administrator on April 23, 2015 at 10:23 am
    How is determining when to recommend tire rotation normally done at your shop?
              Vehicle owner manual recommendation
              Tire maker recommendation
              Tire vendor recommendation
              With every oil change / scheduled service
              With every other oil change / scheduled service
              Miles interval that you decided on:                                miles
              Technician / shop recommendation based on tire condition. (If this is the case, what are your shop guidelines on when to recommend?)
              Other – please describe
    Thanks for your input – all comments welcome.
    Greg McConiga replied 11 years, 5 months ago 3 Members · 2 Replies
  • 2 Replies
  • pridgentire
    April 28, 2015 at 10:34 am
    We recommend every 5,000-7,500 miles …unless we find signs of irregular tire wear which at that time we would recommend a rotation…We tell the customers that its easier to include it in with their oil change….a good way to keep up with it.
  • Greg McConiga
    May 1, 2015 at 8:23 am
    It depends on the vehicle.  A lot of late model cars run more negative camber than older cars and the tires on those cars should be rotated with every oil change… in part due to accelerated shoulder wear and in part due to extended oil drain intervals.  We recommend oil changes based on crankcase capacity and owner drive cycles, with the longest recommendation set at 1000 miles per quart of crankcase capacity.  In our experience the contamination load determines the drain interval.  For large capacity sumps the rotation interval may be shorter than the drain interval… in no case do we exceed 6000 miles for recommended rotation and all rotations come with a free brake inspection.
