Home › Forums › Equipment And Tools › Plastic fuel nipples
Posted by Wayne on October 5, 2011 at 5:42 pmAnyone know of a way to fix Plastic fuel nipple from a fuel pump moduel
newell08 replied 14 years, 11 months ago 3 Members · 4 Replies -
I hope it wasn’t a new module! You could try insetring a piece of steel brake line inside both pieces of the plastic tube. You may have to gently ream it out with a good drill bit, then set the tube with epoxy. Good luck and don’t do it again!
Thanks for the info but what type of glue would not be effected by the fuel
We use quick set epoxy (2 part). Sets up in 5 minutes, good to go in an hour.
sem makes a fast set, 50 second epoxy. can fix almost anything. it can be drilled and tapped. contact your local auto paint store.
