Home » Forums » Equipment And Tools » How To Choose The Right Tire Changer For Your Store?
Home Forums Equipment And Tools How To Choose The Right Tire Changer For Your Store?
  • How To Choose The Right Tire Changer For Your Store?
    Posted by Laila jensen on August 8, 2022 at 11:41 pm
    The market for tire changers is awash with brands from a variety of manufacturers like Corghi, Ranger, Hofmann, and Comb. Each of these manufacturers is trying to put its best foot forward in a bid to win over the trust and loyalty of customers. There is a great brand that includes all the tire changers, and it is a tire changer that can be adapted to every application scenario, and that is the Unite Tire Changer Machine & PULI Tire Changer Machine, as well as having different tire changers fashioned to meet the needs of specific niches.
    Therefore, an auto repair store owner or brand distributor should know the right model for their application. But before choosing a particular tire changer, buyers need to revisit several questions.
    The type and size of wheels that need to be worked on are a must. Knowing the dimensions of the wheels that you want changing, can help you in shopping for the right tire changer. Look at the rim diameter of the tires. 20 to 22-inch diameter is the common measurement of most wheels.
    Second, the type of wheels to be changed. If you know the type of wheels that you want to replace will give you a clearer picture of the tire changer to shop for. For example, with BMW’s flat tires, then you need to consider more
    Light trucks will use a different tire changer from heavy-duty trucks. A shop owner will also need to know if he/she wants to specialize in run-flat tires. These tires allow the driver to continue driving despite the deflated tires. Such tires need special tire changers because ordinary models may not be able to handle them well.
    Which tire changer should I choose?
    The type of tire shop that you want to be – there are many tire shops out there and the tire changer you choose will determine the type of tire change model that you will ultimately settle for.
    With these factors in mind, we now need to look at the different types of tire changers available in the market. Some of these tire changers derive their names from the mechanics they use to change the tires.
    The swingarm tire changers usually are the most affordable changer you will find and is considered “semi-automatic”. The reason being is that you will have to lock the arm into place by tightening it manually. As well as making it fit perfectly with the size of the wheel that you will be changing. But, it does have a quick change tool with infinite tool head positioning that you will be able to adjust to fit nearly any tire. Some great swing arm tire changers that we recommend are the PL-1211, the U-209, and the U-2092.
    Most swing arm tire changers are able to fit bigger tires (Up to 50 inches in diameter). But, the tech would have to adjust it every time to fit the rim correctly otherwise you can damage the tire. This type of changer does come in handy when the shop is constantly doing the same size tires.
    If they are, the tool head does not have to be re-positioned every time. An experienced tech will be able to change plenty of tires in a short amount of time. We recommend using this tire changer if you are starting a shop. Also if you are going to use it for a particular tire size. That way you don’t have to continue changing the tool head every time.
    Tilt Back Tire Changer
    The first thing you will notice about the tilt-back tire changer is the price tag for this machine compared to its little brother. The swingarm. The price tag for the tilt-back tire changers will usually be 1 ½ to 2 times the amount of the swingarm. Yet, you will be able to fit bigger tires. As well as adjust them a lot faster with the automatic tilt back option which adjusts correctly to fit the size of the tire with the press of a button. Some of the models that we recommend are the U-256T, the PL-1226IT, or the PL-1227IT.
    When it comes to changing tires, we usually recommend the tilt-back tire changer. It might be more expensive, but it will be a lot easier to use. You will also have less risk when it comes to damaging tires if you are not too experienced.
    Touchless / Leverless Tire Changer
    The leverless tire changers are considered risk-free and they reduce significantly the chances of damaging your wheels while changing them.
    They are specifically made to help the tech change run-flat tires and also UHP (Ultra High Performance) Tires much easier than with their tire changer counterparts. Even though it is a little harder to learn how to use it, most manufacturers will include training when you buy these tire changers. Some touchless/leverless tire changer models is the U-239.
    Most of these more advanced tire changers have an integrated wheel lift. This helps in handling heavy wheels without the need for lifting hence eliminating operator injury. Powerful pneumatic assistant tools that reduce the effort needed while changing tough-sidewall tires. This enhances a safer and more efficient working environment. It is quick and precise to set up. It makes use of multi-size center cones that make mounting of wheels easy and fast thereby reducing wheel damage. It services a larger range of wheels. This gives it the flexibility to work on a variety of wheel sizes and styles with a lot of efficiencies.
    Our suggestion, have one tech at your shop learn how to use this machine completely and have only his work on it.
    Other types of tire changers
    Motorcycle Tire Changer
    Motorcycle tire changers are less complicated than passenger and light truck changers. This is because they deal with lighter and smaller tires and wheels. Their setup is a lot simpler and they usually have a simple bead loosening system and rim clamps powered manually. Usually, this tire changer only exists in motorcycle repair shops. But if you think you can expand your business by acquiring it, definitely do so. However, you might have to expand to do other jobs for motorcycles, which will be a good problem to have. Check out the PL-1200M and the U-200.
    Heavy Duty Tire Changers
    Compared to the motorcycle tire changer, the heavy-duty or truck tire changer is a monster. These changers usually have to deal with heavy-duty tires that may go up to 91 inches in diameter and 43 inches wide. Be careful when choosing a heavy-duty tire changer. Some are, especially for agricultural, off-road, and constructional vehicles. While others are for businesses that maintain a fleet of vehicles. Unless you are opening up a truck shop. We don’t recommend owning one of these. It’s way too expensive and most trucks will go to specialized truck repair shops. But, if you do have a truck tire changer take a look at the Unite u-298 truck tyre changer, one of our more popular models.
    Other Factors to Consider
    Air VS Electric
    Some manufacturers like Corghi will give you the option of choosing if you want either an Air or Electric Tire Changer. We recommend going with the electric model for convenience and ease of repair. They’re also less expensive to operate.
    110 VS 220 Voltage
    Again, some tire changer manufacturers give you the choice of choosing between 110 and 220 volts. While it is easier to install and set up a 110 Volt tire changer. The 220 will be safer and more efficient because it gives the tire changers a lot more power. Especially when you are changing tougher tires like the run-flat tires.
    Power Operated Assist Tools
    If you want to have a shop that handles modern tires that are tougher. You definitely want to equip your tire changer with a power-operated assist tool. These assist tools will help the technician change the tire much easier and safer and also will increase the productivity of your shop.
    Most manufacturers will have different names for these tools like the Easymont from Hofmann. The SP2000 and PU1500 from Corghi, or the Single or Dual Tower Assist from Ranger.
    Choosing the right Tire Changer
    Selecting the right tools should be about quality as well as durability. We know not every new shop owner can afford top-of-the-line equipment from the jump. But there are a handful of tire changers from well-respected brands that will add prestige to your new shop, without breaking the bank.
    Here at Best Auto Equipments, we carry more than 64 different tire changers from UNITE & PULI brands. Be sure to browse our products page and ask our industry experts about specials and combos.
    We also recommend you check out our blog and learn more about auto repair marketing tips.
    TAGS: , , ,
    Laila jensen replied 1 year, 3 months ago 1 Member · 0 Replies
