Home » Forums » Equipment And Tools » Coolant Flush Machines
Home › Forums › Equipment And Tools › Coolant Flush Machines
  • Tom Piippo
    November 5, 2012 at 4:49 pm
    As with any equipment, there is great wisdom in buying locally. Sometimes the only option is to buy a new one when it comes time for equipment repairs, if there is no service center nearby. However, these flush machines are not too complex and I’ve had good service from my Viper AF2350. Ocassionally the plastic quick connects need to be replaced, and if I get into a real nasty system, the check valve will hang-up, but I can get the parts direct from the factory, shipped overnight if needed.
  • Patrick McElroy
    November 6, 2012 at 2:18 am
    Phil,
    Call Steve Betts from Premaco Michigan. Ask him for a demo of their
    coolant flush machine at your location. They sell BG Products and if
    you use their chemicals I believe they loan you the machine at no
    charge. I have used both their coolant flush and trans fluid
    exchanger machines for eight years now with great satisfaction. The
    coolant flush machine taps into the upper radiator hose and flushes
    the system by forcing the t-stat open and reverse flushes the
    cooling system. There are some cars that you just can’t power flush
    due to access, but I think this is one of the best machines out
    there. Premaco’s office # is 770-425-1844
