Home › Forums › Auto and Truck Shop Management Software › Changing software and finding customer history
Posted by Alan Ollie on April 11, 2011 at 1:06 amI am thinking of changing software and one of the downfalls is the ability to see customer detailed history on past invoices. Any ideas?
baymastersms replied 14 years, 10 months ago 9 Members · 9 Replies -
We’ve changed several times over the years & been able to keep previous
versions running till we didn’t use them any more. As long as you have
the database (assuming it can be opened with MS Access) a decent
programmer should be able to setup a report allowing you a spreadsheet
type view.
Hope this helps. We’re in the final stages of testing to run Protractor
Enterprise (two locations).
What system(s) are you considering? Care to share insights?
Hello,
Check with “PACE” systems. He came from the auto service business in the 8os and I have had his system since. After The original DOS system was updated years ago,they were able to convert and install all past tickets and history to the new system. Very happy with his serive and they are just outside your back door. Hope this helps.
The question is what system are you currently using. We have converted data off of over 50 dofferent shop management systems over the years. However there are some software suppliers that encrypt the data and make it impossible to move your history to a new system. Can’t speak for any of the software suppliers out there but R.O. Writer had a very solid record for doing full data conversions off of legacy systems.
Can you share some of the companies that encrypt data so it can’t be exported?
Depending on the company that you are switching to, they may be able to
convert your data to your new system from the old one giving you instant
access to the much needed vehicle history. I know we have that
availability. What system are you currently using. If you have any
questions feel free to contact me anytime. I am more than happy to help
whether it be our shop management system or others.
Hi, make sure you let us know when/if you change shop management systems. If it’s of any value, we can export your database back to you in a file you can give to your new sms vendor, no charge. Of course it won’t have all the specific vehicle history but at least all the year, make, model, name, address, etc. is available as a back up. By the way, you already have 49 pending on-line reviews for you to post to your internet landing place page, facebook, etc. Lot’s of 5 stars, good job.
The system we changed from encrypted data so it wasn’t available from that source, but since the invoice/vehicle detail was imported into Quickbooks, the guys at TABS were able to pull the detail from there and import it so we could access customer history in the new software, which was an important factor to us. TABS tech support can also import any data that can be exported in Excel format. TABS has delivered what we needed and more. For the record, I do not represent TABS in any way other than being a satisfied customer. And we all know how important that is in our businesses.
I’ve been using this program for 4 years now and its been just great perfect for my use ,
Here is the link maybe it will fit in with your system .
You can call up any history file of the customer or vehicle.
here is there link http://www.autoshopwiz.com/
Regards Greg
Hey,
I have a software Bay-masteR shop management software which allows u to
transfer old data to be viewed in the Bay-masteR software. For more
information call me at 1-800-922-2378
Corey
