Home » Forums » Shop Design & Efficiency » 5s your Shop
Home › Forums › Shop Design & Efficiency › 5s your Shop
  • Posted by randycole on February 18, 2013 at 10:03 pm
    Implementing the strategies of 5s within an auto shop can be a
    daunting task, but the added rewards and benefits at the end will
    defiantly be well worth the effort.
    Many auto shops have excessive amounts of materials, goods and tools
    that are either not needed or just plain out dated and not in use any
    longer. These unneeded materials often handicap often difficult
    organization or work efficiency to take place. In order to rectify
    this problem, the implementation of a 5S program within an auto body
    shop will not only improve productivity but also overall organization
    and even quality of business.
    If you find yourself wasting valuable work time digging around in
    multiple bins looking for needed tools, a foam tool organizer can be
    the right answer for you. A foam tool organizer can actually be easily
    customized to fit any sort of tool that is used on a regular basis,
    all you must do is simply trace the tools that you would like in the
    organizer, cut the foam and peel the back off and stick the foam
    inside either a tool box or drawer. It really is that easy!
    Does anyone here have any recommendations to make regarding auto shop
    organization? If so, please post! Let’s help make our auto shops more
    efficient and effective!
    Resources:Foam Tool Organizers
    http://www.creativesafetysupply.com/Foam-Organizers/
    randycole replied 13 years, 7 months ago 1 Member · 0 Replies
