Home » Forums » Marketing For Auto Repair Shops » What You Want to Know When Building Big Garage Equipment Purchases
Home › Forums › Marketing For Auto Repair Shops › What You Want to Know When Building Big Garage Equipment Purchases
  • What You Want to Know When Building Big Garage Equipment Purchases
    Posted by Laila jensen on May 13, 2022 at 1:30 am
    Whether you’re just now opening your automotive workshop, you’re advancing your outfit, or you’re developing, you’ve picked up a lot of capitalism on the line. It’s vital that you make smart, informed opinions when it comes to the outfit you buy, particularly those large shop outfit purchases. How do you guarantee that you’re making the right choices?
    Connection
    We’ll start our discussion with the content of the connection. What does that mean in relation to large outfit purchases for your automotive shop? Actually, a lot. It means that you need to ensure that the outfit you’re buying will be applicable for use with the ultimate of the vehicles that you will need to service.
    For your case, suppose you were considering the purchase of a new vehicle lift. You find a two-post car lift, swing-arm style lift for a truly reasonable price. On the other hand, there’s a four-post lift, drive-up style lift available, but it costs a significant amount more. You know that you will be servicing not just subcompacts and compact vehicles, but also full-sized exchanges and SUVs, so the most applicable type of lift would be the four-post, drive-up style, rather than the two-post swing-arm style, despite the price difference.
    You need to make this consideration with every major piece of outfit you consider copping. Is the alignment machine you’re looking at suitable for working with the vehicles that you’re likely to service? Do you anticipate doing a lot of high-speed tire balancing, and is the balancer rated to handle the size and weight of the tires you’ll be balancing?
    Automotive Equipment Warranty/ Guarantee
    Investing in major pieces of outfit for your automotive shop should not leave you upset about what you’ll do if and when the commodity goes wrong. You’re putting a lot of capital into that outfit, and you earn a little peace of mind that the manufacturer, or the retailer you buy from, will stand behind the product. Make sure that there is a substantial bond on all of your major outfit purchases, including lifts, tire mount machines, tire balancers, alignment machines, air compressors, individual tools, copse lathes, and the suchlike. The longer the bond, the better.
    You also need to compare bond length and content to open price to make sure you’re really seeing the big picture. A cheaper lift might save you some capital now, but what if it fails just a time or two down the road and there’s no bond to cover you?
    Financing Options
    Provisioning your shop can be truly, truly precious. Utmost shop owners simply don’t have the financial wherewithal to pay for the outfit they need outright, which means you need to seriously consider the backing options available from the manufacturer or retailer.
    What kind of backing packages are offered? What’s the interest rate? Is your business credit sufficient to qualify for a low rate? Would it be better to lease the outfit you need, rather than copping it, indeed with backing? What kind of down payment is demanded, and is there any interest-free period available?
    Support and Service
    All outfits you buy will need a little TLC over time. Wear and tear from normal, everyday use will take its threat on everything from alignment racks to vehicle lifts. Without proper conservation, service, and support, that outfit will eventually fail. What are your options for service, conservation, and troubleshooting if a problem arises? Does the retailer offer the help you need? Is it free with purchase, or must you pay redundant? Is service available through the manufacturer only, or are there other service providers that you can communicate with for cheaper rates or faster service times? Are you responsible for all service and conservation needs with the outfit? If so, does the retailer/ manufacturer give you any type of conservation companion or other paraphernalia to help ensure that you’re suitable to keep up with it? Multiple Options from the Same Source A successful automotive shop needs a lot of outfits. Buying that outfit incremental from multiple suppliers costs you a lot of gratuitous time, and causes a great deal of frustration. It’s a better option to work with a supplier that can satisfy most, or indeed all, of your outfit needs. In multitudinous cases, you may find that you save capitalize on the outfit you need due to bulk purchase abatements or are suitable to take advantage of other impulses offered, analogous as in-house backing, free installation, and the suchlike. Look for a company that can give you bus lifts, tire changers, wheel balancers, alignment machines, A/ C machines, heavy-duty presses, ceiling-mounted sock rolls, compressors, and everything else you need.
    Sedulity Instrument
    While the bond on the outfit you buy offers important peace of mind, you also need to consider whether certain particulars are sedulity certified or not. For case, buying bus lifts certified by the Bus Lift Institute offers quite a numerous benefits over buying lifts that are uncertified. Instrument means that the lift has been fully tested and complies with a set of rigorous morals set by a third party.
    Future Substantiation
    As a final note, make sure that the outfit you buy is as unborn substantiation as possible. This means that the outfit will serve your conditions for a long time to come, but also that it embodies technology that will not be outdated in the coming numerous times. Doing differently is simply a waste of capitalism, as you need a modern outfit to ensure that you’re suitable to serve your guests properly.
    In the End
    Still, you should be suitable to make informed, smart opinions when it comes to the outfit you buy for your shop If you follow the tips laid out in this companion. Cover smart, compare your options, and buy with an eye toward not just financial savings, but quality, support, and durability.
    Laila jensen replied 4 years, 4 months ago 1 Member · 0 Replies
