Home » Forums » Shop Design & Efficiency » U4GM Reviews poe2 Martial Artist Ascendancy
Home Forums Shop Design & Efficiency U4GM Reviews poe2 Martial Artist Ascendancy
  • U4GM Reviews poe2 Martial Artist Ascendancy
    Posted by Unknown Member on June 8, 2026 at 3:48 am
    Path of Exile 2’s Return of the Ancients patch lands on May 29, 2026, and it’s not the kind of update you skim over while waiting in town. This is a proper shake-up. If you care about trading, crafting, or stocking up on PoE2 Items before a fresh league push, you’ll want to pay attention early. Patch 0.5.0 brings the Runes of Aldur league, a rebuilt endgame, new Atlas goals, two Ascendancies, and a pile of balance changes that’ll affect old characters as well as new ones. Existing Early Access characters stay playable, but everyone gets a free passive tree refund because the tree itself has changed.
    Runes, Remnants, and the New Crafting Loop
    The Runes of Aldur league is built around Remnants found in each area. You place Runic Recipes into their slots, fight the waves that come out, then claim the item if you survive. Simple idea, but it can get nasty fast. Remnants can roll from 2 to 10 slots, and using more Runeshapes means more enemy waves with extra modifiers. Farrow, the new NPC, ties the whole thing together through campaign quests. He unlocks Verisium Runeforging, Alloy currency, Unique base upgrades, and Ancient Runes as you move through Acts 1 to 4. Verisium matters a lot here, since it fuels several of these systems and drops from Remnant monsters.
    Runic Ward Changes How Defence Feels
    Runic Ward is probably the mechanic players will argue about first. It kicks in when you hit 1 life, letting Ward soak damage while you cling on. It also regenerates on its own, separate from life. Low-level armour can gain it without a downside, while higher-level gear trades some normal defences for Ward instead. That’s a real choice, not just a free stat. It also affects Trials of the Sekhemas, where your maximum Runic Ward is added to starting Honour. Because old wording around “Defences” has been cleaned up, players will need to read gear and passives more carefully than before.
    The Atlas Has Actual Direction Now
    The endgame no longer feels like wandering until something interesting appears. Patch 0.5.0 adds fixed Atlas points of interest, quests for league mechanics, and deterministic pinnacle boss paths. The new Origins of Divinity storyline starts after the Cataclysm of the Beast and leads into the Fortress system. Fortress maps grant Atlas Passive Tree points, replacing the old method. Since the tree has over 300 nodes and can eventually be fully allocated, respeccing the Atlas matters less than choosing the right multi-choice options. Masters of the Atlas adds another layer, with Doryani, Hilda, and Jado offering map-specific bonuses you can swap before running content.
    Old Mechanics Get New Reasons to Run Them
    Delirium, Breach, Ritual, Fate of the Vaal, and Expedition all get serious attention. Delirium has a new progress bar and a shorter Simulacrum structure. Breach now pushes toward Stabilised Breaches and the Genesis Tree. Ritual offers more focused rewards, plus new boss routes through Caer Tarth. Fate of the Vaal becomes core, starting in Act 3 and expanding into Atlas content. Expedition is folded into the Runes of Aldur setup, while logbooks become Ocean Exploring. That means islands, faction leaders, and a route toward the league pinnacle boss instead of the old familiar loop.
    Build Planning Won’t Be Business as Usual
    Two new Ascendancies should freshen up character planning. Martial Artist gives Monk players illusions, body runes, bells, and unarmed options. Spirit Walker gives the Huntress animal spirits, beast binding, and a spectral companion angle. Add in leech changes, the Tempest Bell limit, new Kalguuran skills, fresh support gems, and client-side build guide files, and you’ve got a patch where copying last season’s setup may not work. Players looking for cheap PoE2 Items will still need to think about new gear priorities, especially around Runic Ward, crafted modifiers, and the changed value of defensive bases.
    Unknown Member replied 3 days, 14 hours ago 1 Member · 0 Replies
