U4GM poe2 Planner Guide for Patch 0.5 Builds
Planning a PoE 2 build is still a bit scrappy, honestly, but it’s workable if you treat the current tools like a workshop, not gospel, and compare passive ideas with your own PoE2 Items needs before locking anything in.
PoE Planner gives the clearest raw tree picture
PoE Planner is the tool that actually shows the numbers most players want to see first. Its Path of Exile 2 page lists planner version v2.10.6.0, while the passive tree itself is shown as Tree Version 0.5.0. That matters, because people searching for 0.5 builds need some sort of visible version marker. Still, don’t read too much into it. The site also says it isn’t affiliated with Grinding Gear Games, so that tree label is useful, but it’s not the same thing as official patch documentation.
- Start with the class selector, then leave ascendancy empty if your route isn’t settled yet.
- Watch the 0 of 122 passive counter before theorycrafting some impossible late-game monster.
- Use node search early, because dragging across a huge tree gets old very fast.
Maxroll works better as a guide hub
Maxroll’s Path of Exile 2 planner sits inside a much wider hub, and that changes how I’d use it. You’re not just staring at a passive tree there. You’re near news, patch notes, class pages, ascendancy builds, mechanics writeups, currency coverage, and campaign help. That’s handy when you’re not sure why a build path exists in the first place. The catch is simple: the available source doesn’t show Maxroll’s tree version, point totals, import tools, notes, or Oracle node support, so hard comparison gets thin pretty quickly.
- Use PoE Planner when you need visible passive totals, ascendancy totals, and attribute tracking on screen.
- Use Maxroll when you want surrounding context, especially guides, mechanics pages, and campaign routing.
- Don’t assume both planners update at the same speed unless each page actually says so.
Reality check: a clean planner link can still fall apart once drops, sockets, and boss pressure show up.
The 0.5 and Oracle stuff needs careful handling
The biggest trap right now is acting like every 0.5 search result proves a real balance change. PoE Planner shows Tree Version 0.5.0, and its interface includes Oracle nodes, which is interesting. Very interesting, actually. But the sources don’t explain what Oracle nodes do, where they sit, or whether they connect to Oracle Totem talk at all. A video title mentions a 0.5 Oracle Totem Update, build files, and a loot filter, but without transcript details, that’s just a lead. Not mechanics you can safely build around.
- Don’t treat Tree Version 0.5.0 as official patch notes from Grinding Gear Games.
- Don’t assume Oracle nodes and Oracle Totem builds are the same thing without real evidence.
- Don’t copy a campaign file blindly unless you understand the passive path and gear pressure.
Keep your planning flexible
The safest move is boring, but it works: plan passives, track attributes, write notes, export builds, and save after login if you’re using PoE Planner seriously. Then check guide context elsewhere and keep room for better PoE2 gear as your character actually develops.
