• May 17, 2019 at 9:12 pm#89217
    HARRY DEKEYAN
    Participant
    Hello!
    I hope you all have had a great week!
    Issue:
    Arago 3D3 Visualiner John Bean
    Track Width is 10″ larger in the front than in the rear.
    Toe is incorrect, when setting to spec on the john bean machine the wheel is turned to the right (going straight), car is moving the left when letting go of the steering wheel.
    The readings are constantly change after each alignment. I adjust the car per the alignment machine and everything is green.  I then proceed with starting a new alignment on the same car, alignment rack has not been moved, the readings show that i’m in the read on the right side.
    We have had a technician in here for the last 1.5 months trying to figure out the issue.
    The machine is used, and not once has it ran a proper alignment. The Toe is constantly incorrect.
You must be logged in to reply to this topic.
