Home › Forums › Equipment And Tools › Two Questions about Alignment Equipment
Posted by Site Administrator on December 2, 2015 at 9:43 am1: What brand alignment machine do you have?
Ammcoats
ARI-hetra
Atlas
BeeLine
BendPak – Ranger
Bosch
Branick
Corghi
Dannmar
ESCO
Hofmann
Hunter
JohnBean
Ken-Tool
Launch
Nussbaum
Ravaglioli
SUTO
TEC
TSISSGNote: Links to each of the companies above can be found on this page https://www.automotivemanagementnetwork.com/tools/shop-owner-resource-directory/#Tire-and-Wheel-Equipment2: On a scale of 1-10 how happy are you and your techs with it?#wheelalignmentequipmentTom Piippo replied 8 years, 3 months ago 7 Members · 6 Replies- 6 Replies
Hunter Hawk Eye – been doing alignments for 35 years, best system i ever used. #10
Tru-lign,TL-12 with one ton dually kit. I bought this because I am a small one man shop without a bay for an alignment rack, the system wasn’t terribly expensive and I can use it with wheel stands. I would not recommend this system, has been one issue after another seems like, and I just don’t trust it to give me an accurate toe reading. In a shop my size ROI also just isnt there, but there is no where close I can sublet an alignment out to that I would trust.
We bought a Hunter Hawkeye camera system a couple years ago. It was the third new system we had bought. The first was a hunter in 1980. The second was a FMC in 1995. We bought the FMC because at the time Hunter swore that they were dedicated to the upgradability of their 111 series through the end of the century. We/I wanted a PC based tool that I could network so that I could have Alldata and my shop management system on the same computer to save steps. After we bought it, not two months later Hunter hit the trade magazines with their PC based tool that “could run your whole shop”. Anyway, the FMC was by far the most accurate and repeatable of all the tools.
I love the Hunter camera system since it reduces the work tremendously. It cut the time to do an alignment in half. But I have measured cars numerous times for various reasons and the repeatability just isn’t where the non camera system had it.
We have 5 other techs that are using the Hunter regularly. Three of them were not here when we had the FMC, the rest love the Hunter for the ease of set up.
The main reason we changed from the FMC (which was working just fine) was that two car manufacturers that we do a lot of work on (BMW and Porsche) have stated that alignments to their cars can not be done after the car has been lifted until the car has driven at least a mile. That meant that standard wheel run out calibration was not acceptable. The camera systems just roll the car forward and backward which is acceptable.
John Beam (on our second JB camera system)
Rating: 7 1/2
Purchase Date: 2011
Pros: Accurate, Repeatable, Fast
Cons: Software not as intuitive as you would think it should be, as to finding things like customer files, etc
PC / hard drive crashed in 6/2015 (had to replace + updated to latest software)
We
bought our first John Bean camera system in 2001. Going to a
camera / rollback system did reduce the work tremendously. It cut the
time
to do an alignment in half & more at times. All our techs use it
whereas before only 1 or 2 did alignments. Have had no issue with
repeatability.We have 5 Techs that use it regularly, about 1/2 said 8 the others 7. (I don’t know that any would give anything a 10)
I have used various models of Hunter equipment over the years. I bought the Hawk Eye system 4 years ago and is by far the easiest and most robust of all the previous models. The car is set up and angles acquired in 10 minutes or less from the time it rolled on the rack. Now, making the adjustments…?
